Hi there am starting to learn about overclocking and i have an i7 7700k with a kraken x62 and my temps without any overclocking are around 35c to 38c but i have to have fans on or around 70% is this ok or is it a bit high for water cooled as if i have fans turned down my temps sit around 45 to 51 c
https://linustechtips.com/topic/754016-intel-i7-7700k-temps/
your perfectly fine, only thing you shouldn't hit is 80-90°C
everything below 50°C under load is very very cool, so slow your fans down and be happy about silence and cool computing ;)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/754016-intel-i7-7700k-temps/#findComment-9537994
