Hi everyone,
I just added 2 HDD to my system. It are 2 old and used HDD. But I can't find them in my computer. If I go to disk manager I can see them. I heard I need to write a letter but I'm not sure how. Can someone help me?
If you need pictures leave a comment :D
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/753992-help-with-hdd/
Go into disc management. You will find them there if they are recognized by your system. They will be in a black outline in the graphical output down below. Right click on it and format the drives for them to be picked up and accessible for use.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537840
12 minutes ago, Walt said:
Hi everyone,
Thanks!
Hey there! To assign a drive letter to these drives, you need to open up Disk Management, and do it from there.
  • Press WINDOWS + R on your keyboard
  • Type in "diskmgmt.msc" and press ENTER
  • Right click on the drive/partition you need to work with
  • Assign a drive letter / delete partitions / format drives
If your drives don't show up as usable, attach a screenshot if you can and I'll try to help.
If they don't show up at all, you may need to force Windows to detect them in Device Manager.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537846
This is what I get: IMG_8862.JPG
And I can't press Change drive letter and paths. It's light gray
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537862
See the bottom picture with the graphical portion, there is a scroll bar to the right. Below that is where you will find the ones I mentioned. Once you find them, then you will be able to format them.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537866
1 minute ago, Walt said:
This is what I get:
In the future, when you quote, backspace/delete the quoted images to save space and server load. :)
The two drives you're talking about are 2TB models, I presume?
If so, can you right click on the 1862.70 GB partitions and choose "Assign Drive Letter" ?
If not, what did they come out of, and does the data on them need to be accessed or can they be wiped completely clean?
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537872
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537874
will be below it all. It will be new simple volume is what you want to select.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537876
They come out an old IMac and the data can be deleted.
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537877
Okay it worked. It shows them in my computer. But now they are both 126MB instead of around 2 TB. Why?
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537885
Since they were old drives, you likely will need to wipe them. Try using this guide to help you with that.
http://www.winability.com/delete-protected-efi-disk-partition/
Community Standards
"Beast Mode"
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537890
@legacy99 @kirashi
You'll need to wipe them if they came out of a Mac since their filesystem formatting will be HFS or HFS+ and not FAT32 or NTFS.
You can do this by right clicking on ALL of the blue partitions on each drive, and choosing delete.
Then right click on the black partitions (unallocated space) and create a new partition using NTFS as the filesystem.
If this doesn't work, let me know, and I'll have to walk you through some more advanced and careful command line based steps.
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537895
@legacy99 @kirashi
It worked! Thanks both of you!!! :D
https://linustechtips.com/topic/753992-help-with-hdd/#findComment-9537903
