this is my modest build i have not decided on CPU cooling as of yet bold lines are bought already
Corsair Graphite Series 760T Full Tower Windowed Computer Case
ASRock Fatal1ty 990FX Killer AM3+ ATX AMD Motherboard
AMD FX 8370 Vishera 4 GHz Eight Core AM3+ Boxed Processor with Wraith Cooler
ASUS Radeon RX 480 ROG STRIX Overclocked 8GB GDDR5 Video Card
Corsair Vengeance Series 16GB DDR3-2400 PC3-19200 CL11 dual channel desktop memory kit two 8GB memory modules X2
Seagate Barracuda 2TB SATA III 7,200 RPM Internal HDD - OEM X2
EVGA SuperNOVA 1000P2 1000 Watt Modular ATX Power Supply
960 EVO Series 500GB NVMe M.2 Internal SSD
ASUS VP278Q-P 27" HD LED Monitor X2
https://linustechtips.com/topic/753472-opinions-on-cooling-please/
1 minute ago, arakrune said:
why would i return it got it little over a month ago
because it's an old architecture
will bottleneck your rx 480
and slow too
should have asked before making a purchase
do you plan on overclocking? stock should do but you can look at Cryorig H7 as an option
and slow too
not for gaming really   the rx480 is more for the number crunching
not looking for fps speed  more for rendering  and  some editing
an i5 will still pull ahead though but since you already made the choice then nothing can be done
2 minutes ago, KeemoSabe said:
Then go with this one:
Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler
This will give you a better headroom if you plan to overclock your CPU.
AMD FX cpus overclocks better compared to Intel ones so I think overclocking your chip is a must if you have the money for an AIO cooler.
@arakrune I have to agree with @deXxterlab97 about the CPU, if you got it when you said you did, then Ryzen was literally weeks away from releasing, and an i5 would have been a much better choice for gaming, and would be much more efficient. This is not to mention you really don't need a 1kw power supply. Granted, Im one to talk, but the G3 is not only less expensive, but also borderline 80+ Platinum (according to JohnnyGuru http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=494)
I'd honestly recommend going with an AIO, especially if you are going to overclock if you don't want to worry about clearance issues with beefy heat sinks.
problem is, looks like he's already settled with his 8370. @arakrune , just get the AIO liquid cooler and get the best OC out of your CPU.
 the power supply choice is partly due to  later might add  more to the system  i am leaning towards the aio keemo sabe suggested  if only for the overhead
my current system run a bit hot  honestly though it could have better than a t4 on it i admit
honestly when it comes to the cpu i rarely  get the newest thing out  i don't care to pay premiums to be a guinea pig tester
An AIO would be a better option in my opinion. It's not everyone's tastes, and I understand wanting to think about future expandability. I'd honestly consider a G3 over a P2 though.
This is where a i5-6600K would have been great, especially if you wanted to game and wanted to overclock.
8 minutes ago, arakrune said:
what is odd to me is most water cooling say they work for am3 socket  but don't list am3+   are they that close i haven't checked
Yes they are pretty much the same. I already tried installing a bracket from an AM3 to an AM3+ build.
