I have am going to build a computer with the fallowing pc part picker list and the use the fallowing water cooling parts. My question is will it be silent? i wInt this to run silent and am willing to replace the stock fans in the case if needed. Compatibility checks are also appreciated since this will be my first water cooling build...
https://pcpartpicker.com/list/y7KsxY
water cooling parts
https://www.ekwb.com/shop/checkout/cart/
https://linustechtips.com/topic/752907-new-water-cooler-help/
water cooling parts
Hi, You cant put a link to your cart as it saves items in your cookies or something so we cant see them.
https://linustechtips.com/topic/752907-new-water-cooler-help/#findComment-9526009
Ctrl + G, Find and Replace,
Find what: fallowing
Replace with: following
1. Get a 7700k
2. Why so much on custom loop? You could have spent less and get a 1080 or so, GTX 1070 at 1440p and 144hz could be challenging
3. No need for platinum PSU that's way overkill
https://linustechtips.com/topic/752907-new-water-cooler-help/#findComment-9526011
1. Get a 7700k
Would this be better? I liked the fanless psu so i might go back to that but with the 1080 its pushing the power limit. Do you guys know about PSU's where the fan turns off if its not stressed.
https://linustechtips.com/topic/752907-new-water-cooler-help/#findComment-9527592
