Cheap Audio Interface
Go to solution Solved by anothertom,
4 minutes ago, UberGamerKing said:
Not sure what you mean by 'Audio Interface'
Audio Interface - an interface for audio, not sure what part of that is difficult.
@Abdul201588 The behringer UM2 is currently around £30 is good for a single mic input. The UMC22 or UMC202 are similar products but slightly more expensive.
Hi people! I'm looking for a cheapish audio interface, budget is around £40-50 max. I'll be using it for recording videos, setting up a podcast.
Thanks. :)
https://linustechtips.com/topic/752262-cheap-audio-interface/
https://linustechtips.com/topic/752262-cheap-audio-interface/#findComment-9519145
10 minutes ago, johnny5c said:
I'm using a Steinberg UR12 at work and it's pretty impressive for the price,
https://www.amazon.com/exec/obidos/ASIN/B00QY4RLRQ/ezaudiointerfaces-20
£79 :/
Alright, thanks. :D
https://linustechtips.com/topic/752262-cheap-audio-interface/#findComment-9519198
