Hey guys, I could really use some help. I tried to over clock my 6600K. I have an EVGA Z170 FTW and it's always been a little weird when I OC. When I pressed F10 to save and restart, my PC showed the code, 4C. So I cleared the CMOS and proceeded to wait until it booted back up and try again. That didn't happen, the diagnostic thing on the Mobo showed "C". Looked it up and tried everything I could think of. I even took out the battery for 10 mins. Still not booting. Does anyone know what's going on?
https://linustechtips.com/topic/752028-pc-will-not-boot-after-clearing-cmos/
Wait a few seconds for your pc to restore the settings. My motherboards takes about 30 seconds for that to happen (it looks like doesn't post)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
What do you mean by this? Also,  ow when I press the CMOS button, it doesn't do anything.
Boot up the pc with the CMOS battery intact and wait for about half a minute. It would appear as it doesn't POST but after a while it will boot.
Okay so that didn't work. Should I take out the battery again and repeat the process? Still shows "C"
power off your computer
flip psu switch (on -> off)
press the power button
wait 10 seconds
pull out the battery
flip psu switch (off -> on)
wait 10 seconds
put in battery
wait a few moments
press on pc
wait 30 seconds
should post (if the problem was to do with the CMOS battery and nothing else hardware related)
wait 10 seconds
wait 10 seconds
put in battery
wait a few moments
press on pc
wait 30 seconds
Okay I did that and still nothing. What could it be?
Just now, jackychan4899 said:
No I mean the coin cell battery itself, the cmos is the round coin shape battery and it could have died, you should just be able to buy one of those somewhere though
Is it special? Cause it looks like a simple watch battery.
"Obtain battery information
Unfortunately, most manufacturers do not list the exact type and model of your CMOS battery. It is recommended that, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the retail location.
Tip: For most computers, the model or part number for this battery is CR2032."
It's probably the most inexpensive problem that's probable but I personally have never had one die
6 hours ago, ZanyIllusions said:
No, I didn't even touch the Voltage.
Didn't touch the voltage?
Did you allow the bios to set what ever volts it wanted?
When you up the multiplier the voltage also goes up. Some motherboards do a little, some do a lot.
You should always control the voltage when overclocking.
What clocks were you after?
It's not a race to the bottom.
I was at 4.2 and tried to get it to 4.3 and that's when everything went wrong.
