1 minute ago, PapaJohn said:
Can I start a computer without a cpu fan? How do I know if lga 1151 cpu pins aren't bent (top/right section)? And ez dbug is showing a light on cpu and vram. Meaning?
You can start w/o a cpu fan but only for few seconds as it will overheat and can damage your CPU
https://linustechtips.com/topic/751850-questions-on-cpu/#findComment-9513917
5 minutes ago, PapaJohn said:
It goes from vram to cpu. Back to cram and stays solid
make sure your ram is in the correct slots. some boards are REALLY FINICKY about where the RAM is when it's not full.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/751850-questions-on-cpu/#findComment-9513957
You look at them. if they don't look like the others around it, there's something wrong. and they are probably bent.
System specs:
https://linustechtips.com/topic/751850-questions-on-cpu/#findComment-9513960
Please don't try to start a computer without a cooler on your CPU. It absolutely totally under all circumstances needs one.
https://linustechtips.com/topic/751850-questions-on-cpu/#findComment-9514001
Not really to see if a computer will boot is the only cirrcumstance that you don't need a cooler.
https://linustechtips.com/topic/751850-questions-on-cpu/#findComment-9514094
