vibration and noise
Go to solution Solved by Peter041098,
The fans can be held in by rubber pins which limit the number of things that make noise in a case, just screw the drive in before moving the system
Just now, Peter041098 said:
You can try using rubber bans to hang from something in mid air should stop it from being a factor, any other fans in the case?
but i move the oc round every so often so i wouldnt want to do that incase i damaged it in transport or moving :l
yes i have 2x120mm BeQuiet! Purewings 2, the stock 120mm NZXT fan in the rear and the 120mm that comes with the CM Hyper 212 Evo
https://linustechtips.com/topic/751388-vibration-and-noise/#findComment-9508802
