problem with my internet
Go to solution Solved by Technomancer__,
On 3/14/2017 at 4:10 PM, paddy-stone said:
I just realised something, I don't recall you trying a different cable to your PC?
i did
btw i fixed the problem
i reset the router and the problem got away
btw after a while i had another problem. the router was dropping packets. it was thermal throttling so I put a fan there. now it works just fine
when i start my computer i get DNS errors and sites on chrome and programs wont work but after a while its fixed
i cheeked my DNS setting and they are fine. they are the same with the other computers in my house which work fine
it doesn't happen to any other pc or device in my network
https://linustechtips.com/topic/751090-problem-with-my-internet/
Since you have good DNS settings, the next most common cause of this issue in my experience is packet loss, whcih can be caused by a number of isses. How is this computer connected to the network? If it's wireless, how good is the signal strength that the computer receives?
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9506268
wired gigabit with cat 6
other computers also in the same switch work fine
i also get 0 packet loss when i ping to 8.8.8.8
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9506520
That is a good test, but a better one is MTR, or you might look up WinMTR. MTR is like running traceroute every few seconds, and if you let it run for an hour or more in the background it will give you a good idea whether you experience any packet loss at all - if you try to run ping or traceroute manually when you experience an error loading a website, most of the time the issue will have already passed before you can start your test. MTR is open source, and there are a few Windows ports of it available. The one that I use is http://winmtr.net/download-winmtr/
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9507289
i will try it when i get home thanks
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9510620
12 hours ago, bcguru9384 said:
for what ever reason my home modem sets dns to gateway ip
192.168.0.1
not sure why so i use google as dns1 and the modem choice dns2
but my isp has always been cryptic about their dns server ip
i get this
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9513360
1 hour ago, Ethocreeper said:
i get this
try leaving it running for a long time - at least an hour. you specifically want it to already be running when you get that DNS error in Chrome, check what WinMTR shows right after you get one of those.
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9513985
Have you tried flushing the cache, just in case... you can do that with ccleaner even.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9514240
do you mean the browser cache. yes in fact it auto cleans every time i boot my pc. i can see it empty and its not only the browser other software too.
for a strange reason now it works better i just changed my psu and case.
i will retest and sent a new screenshot when i go home.
thanks in advance
lol we are now 3 with the same problem
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9516278
Ahh I see, yes I also have that on my windows PCs, use ccleaner to clean when windows starts to flush out the browser cache and loads of other stuff.
So this is now a problem on 3 PCs?
If so, I would be leaning towards there being a problem with the router... it is possible that the PCs are all at fault, especially if they are all using the same DNS settings etc, but less likely is all. First off what I would do is change them all to DHCP and see if that makes a difference, then check the router's settings. see if there are any conflicting reservations etc. If you can't find anything, I think my next course of action would be to save the router's settings so that you can go back to that any time you want - and then reset the router, put in whatever info you need to get the basics working like internet and any address reservations or DHCP range to avoid conflicting static addresses from devices. Then set your PC back to DHCP (if not already) and see if you still get the problem... if you don't then it might have been some setting that got confused somewhere, and you should be able to narrow it down, by changing settings one at a time until the problem occurs again... if it doesn't do it anymore then that's great.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9517493
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/751090-problem-with-my-internet/#findComment-9517503
  • 5 months later...
i did
