Case fans problem
Solved by WoodenMarker,
22 hours ago, MuRado said:Here is a picture of what I've tried. *See Picture*
On the picture I have the 2 front fans plugged into each other using 4pin large molex, this connected to the fan on the back which using another large molex, this leading back to the CHA_FAN_2 on my mobo using 3pin
The 4pin molex connector just provides power and the psu doesn't provide any form of control.
The 3pin connector is just for reading rpm when the 4pin molex connector is used. If you want to control the fan speed, try connecting only the 3pin fan connector.
