Here is my first personal pc (2nd overall) I have built:
CPU: AMD Ryzen R7 1700
GPU: Sapphire Nitro+ RX 470 8 GB
RAM: Corsair Vengeance LPX 32GB (2x 16GB) DDR4 2666MHz Memory (White)
Storage: SanDisk Ultra II 960GB SATA III SSD
OS: Windows 10 Home (64 bit)
PSU: EVGA SuperNOVA 750W G2 80+ Gold Modular Power Supply
Fans: 4x Noctua 140mm NF-P14S Redux Edition 1200RPM PWM Fans
Monitor: Viewsonic VX2457-MHD 23.6" Full HD 75Hz 1ms Freesync LED Gaming Monitor
Case: Corsair Carbide 400C (White)
Edited by Greenver_420
CPU Name    AMD Ryzen 7 1700 Eight-Core Processor
Frequency    3192.38 MHz (32 * 99.76 MHz) - Uncore: 1064.1 MHz
Motherboard Model    Asus PRIME B350-PLUS
Socket    Socket AM4 (1331)
Memory (RAM) Total Size    32768 MB
Radeon (TM) RX 470 Graphics (Polaris) [8192 MB]
SanDisk Ultra II 894.3 GiB (~960 GB)
Western Digital WDC WD5000LPCX-60VHAT0 465.8 GiB (~500 GB)
ViewSonic VX2457 (VSCB931)
Microsoft Windows 10 (10.0) Home 64-bit
https://linustechtips.com/topic/750583-my-first-personal-build/
I was thinking of getting the Ryzen R5 but was too impatient to wait until Q2 and I am only aiming for gaming at 1080p60.
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500704
Just now, Littlelaner said:
Hate to be that guy, but have you thought of cable management?
I have but one of the fan headers and the CPU connector are in quite awkward positions on this motherboard and I would have to purchase a extension for the CPU 8 pin to try and tidy it up.
I also play emulated games on this machine so I think the extra cores help.
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500730
Is there no cut out above the motherboard to thread cables through in your case?
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500737
9 minutes ago, deXxterlab97 said:
I am saying about RX 470
Yes but you're talking about an RX 470 being underpowered for an 8 core. Would you have said that for a 4 core? They are the same price. Logically, consumers would buy the best looking one.
Please stop disregarding information and then saying someone is wrong. This isn't the first time you've done it.
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500769
So why comparing it with an i7 7700k?
What I meant was a higher end GPU would be nicer to have with an R7 not that he should downgrade his CPU
I did not know what he was doing
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500771
There is but it is awkward for the 8 pin CPU to fit because of the restriction of the size of the hole by the motherboard and my top case fans.
Here is some photos after I did a bit more cable management.
The Elgato HD60 pro is currently not in use due to and issue with it and Ryzen. I have notified Elgato support about the fact it is not working.
https://linustechtips.com/topic/750583-my-first-personal-build/#findComment-9500796
