Hi! Ok, so, the other day i went and calibrated my controller, but now for example if a turn right in forza (using the left analogue) it also looks right (which the right analogue is used for), as this is going on i cant accelerate or brake or do anything for that manner. When i click "reset to default" in the controller properties, nothing happens. If i try and calibrate it again, it skips through multiple slides of the calibration setup when i press any button! Even when i uninstall the xbox 360 drivers and reinstall them it doesn't fix the issue. Iv'e talked to 3 people from Microsoft and have gotten no where.
So basically, i caused it all to fail just by trying to calibrate it. Are there any files i can delete that might save info about the controller? I need to do a fresh controller install somehow. Can anybody help at all? If not i might just reinstall windows...
https://linustechtips.com/topic/749915-xbox-360-controller-issue/
