I stumbled across this absolute beauty shopping around on amazon, hands down the best looking pc ive seen TBH. Anyway, does anyone know of any premade screens like this that can run off of molex/sata power, and have a DP/HDMI/whatever connector, or is this something I build from the ground up with an old screen? I've looked around a bit and havent heard or seen anyone else doing this, with the exception of ibuypower's snowblind, but thats different.
Fanboys are the worst thing to happen to the tech community World. Chief among them are Apple fanboys.
https://linustechtips.com/topic/749528-internal-lcd-for-cam/
You can get little screens like this that take an HDMI input and 12V power or in this case regular USB.
https://www.adafruit.com/products/2406
https://www.adafruit.com/categories/506
https://linustechtips.com/topic/749528-internal-lcd-for-cam/#findComment-9488950
That's exactly what I was looking for! Thanks mate!
Slap a skin on the outside, cut the factory screw mounts off, and power this off a MOBO usb 2 header and I think I'll be good to go
https://linustechtips.com/topic/749528-internal-lcd-for-cam/#findComment-9488983
Should work quite well all it would need is to be configured as a secondary screen and default the CAM software to it.
https://linustechtips.com/topic/749528-internal-lcd-for-cam/#findComment-9488994
