I'm looking to build my first pc after being with Xbox for 9 years and their customer service di* king me over.
My budget is £650 ($1200CAD $990USD)
I have two lines of thought.
Either an i5 7500 build https://uk.pcpartpicker.com/user/erridge92/saved/C9DMpg    total price £432.12 ($791.60CAD $655.52USD)
Or an i5 7600K build https://uk.pcpartpicker.com/user/erridge92/saved/Fb6P6h       total price £496.35 ($909.26CAD $752.95USD)
That leaves me with £215 ($394CAD $326USD) For a GPU on the 7500 build or £154 ($282CAD $234USD) For the GPU with the 7600K [I can go £20 {$35CAD $30USD} extra for an amazing GPU]
I have no room for a monitor so I'd be using my 43" 4K Samsung TV over HDMI as my screen. Ideally I'd like the closest resolution to 4K for gaming as possible and I'm ok with 60fps. I also want to be able to watch 4K Netflix/Amazon Prime/YouTube but that could probably be handled via on board graphics.
Also I have a 320GB HDD I can use from my old laptop for extra storage plus an external 1TB HDD I can reuse from my Xbox.
Any suggestions on a suitable graphics card would be greatly appreciated.
Also if you know of a reasonable mouse/keyboard (does not have to be RBG at all) that would be really cool too.
{Prices and exchange rate correct at time of posting}
https://linustechtips.com/topic/748747-building-my-first-pc/
Go for the 7500, get a rx 480, and don't buy a aftermarket cooler. Also I doubt these cards cam run 4k@60
Edited by QuantumBit
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480376
Theres essentially almost no way you can run demanding games @ 4k with a 200$ card, so i would suggest turning the resolution down to 1080 or 1440p when gaming.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480381
Though you will have no problem with media consumption at 4k, gaming will definately be a problem unless you plan on playing very low spec games
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480383
Just now, cj09beira said:
you never know what you are getting into with used parts, as a first pc i would not advise it
however if he wants 4k gaming on a £650 limit no much you can do Plus if something doesn't have a moving part it can last soo much longer
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480408
PCPartPicker part list: https://uk.pcpartpicker.com/list/7dKTD8
Price breakdown by merchant: https://uk.pcpartpicker.com/list/7dKTD8/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  (£187.99 @ Aria PC)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  (£42.30 @ Novatech)
Memory: Team Elite 8GB (1 x 8GB) DDR4-2133 Memory  (£47.75 @ Amazon UK)
Storage: Kingston SSDNow UV400 120GB 2.5" Solid State Drive  (£47.54 @ PC World Business)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  (£149.99 @ Amazon UK)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  (£41.39 @ Aria PC)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.95 @ Ebuyer)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  (£26.52 @ Aria PC)
Total: £593.43
Generated by PCPartPicker 2017-03-07 12:12 GMT+0000
There.
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480413
its a tv it doesnt matter if its 4k or not,
the lagg is so bad he wont notice if its below or above 30 fps (even  at 4k)
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480414
This is probably your best option for sub £200 for the gpu.
https://www.overclockers.co.uk/asus-radeon-rx-480-dual-oc-8192mb-gddr5-pci-express-graphics-card-gx-40v-as.html
Or the 4GB version for £30 less.
https://www.overclockers.co.uk/asus-radeon-rx-480-dual-oc-4096mb-gddr5-pci-express-graphics-card-gx-40x-as.html
You are not going to get 60fps at 4K though.
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480418
if you're willing to skip out on the ssd and can spend abit extra:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor  (£168.59 @ Aria PC)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  (£42.30 @ Novatech) find out if the bios supports kabylake.
Video Card: MSI GeForce GTX 1070 8GB Video Card  (£334.98 @ Novatech)
Case: BitFenix Nova ATX Mid Tower Case  (£23.04 @ Aria PC)
Total: £666.61
Generated by PCPartPicker 2017-03-07 12:35 GMT+0000
https://linustechtips.com/topic/748747-building-my-first-pc/#findComment-9480471
