PC Project Help
Solved by plus,
56 minutes ago, razorthekid said:So recently I found this:
3.00GHz E5450 Quad Core QC Intel Xeon Processor SLBBM SLANQ
As cheap as used E5450s are right now (~ $ 20,- on ebay), there's not much at risk. If you're not scared of modding, there are some LGA775 boards to play with. An example would be the Asus P5Q-E, worth $ 99,- back in 2015.
