H81 supports overclocking. All Haswell chipsets 'unofficially' supports it.
https://forums.anandtech.com/threads/what-motherboards-have-non-z-overclocking-enabled-for-pentium-3258.2389948/
But don't push G3258 to its limit, since H81 mobos are not that sturdy.
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9472960
would a 4.0 ghz overclock be safe?
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9472970
1 minute ago, Droidbot said:
no, but it has 2 extra threads, which allows it to actually RUN some games that the G3258 can't.. and with a 480 it smashes the poor 3258 into the ground
is it the same chipset? how do you think it would perform with a 1050ti?
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9473089
@Drwilyam Yes ASRock H81M-ITX is compatible with the G3258 and don't mind other user who keep saying Overclocking is not supported on H81 and go with Z87 and Z97 they don't have a clue what they are talking about.
You could get well over 4.2 to 4.4ghz if your voltage is under 1.300 your stock cooler should handle a peek of 68c to 72c on gaming.
and you should upgrade the mobo's bios to the specific were the g3258 is supported.
http://www.asrock.com/mb/Intel/H81M-ITX/?cat=CPU
Disclaimer Note: to all other user that keep insisting that H81 can not oc the g3258, please don't spread fall information if you have no knowledge about the topic.
GAMING RIG
i5 4590 / 16GB / RX 480 8GB
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9473383
Anything to back that statement? I also have a H81 chipset
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9473398
Can you please stop this stupidity i never said all H81 chipset i said the board he's using, you can be helpful or just useless by simple not disrupting the Topic. @deXxterlab97
and i just said that you should even upgrade the bios to w/ g3258 is supported.
GAMING RIG
https://linustechtips.com/topic/748105-h81-itx-overclocking/#findComment-9473415
