5 minutes ago, Mando said:
I want to be able to run games such as the witcher 3, gta v, fallout 4, ark, and the forest at high,max settings 60 fps+. Anything thing I should change to get better performance and possibly keep the price around what is or maybe less
https://pcpartpicker.com/list/JfgHQV
At 1080p yes. At 1440p probably medium to high 60+depending on game.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9471586
The Cryorig H5 Ultimate has a memory module height limit of around 35mm. G.Skill Ripjaws V modules are 42mm tall.
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9471594
I would go locked i7 instead of unlocked i5, even better if you can get an unlocked i7.
@Princess Cadence and @stealth80 can back me on this one, check out stealth's thread here
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9471636
indeed I will haha
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  ($302.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI Z270 TOMAHAWK ATX LGA1151 Motherboard  ($133.89 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($109.88 @ OutletPC)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($92.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($379.99 @ Jet)
Case: NZXT S340 Elite (Black/Red) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.89 @ OutletPC)
Monitor: Acer GN246HL 24.0" 1920x1080 144Hz Monitor  ($188.99 @ B&H)
Total: $1451.61
Generated by PCPartPicker 2017-03-05 17:39 EST-0500
same build, $2 less with i7
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9471847
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($338.77 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.99 @ Newegg Marketplace)
Motherboard: MSI Z270 SLI ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($99.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.88 @ OutletPC)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1452.90
Generated by PCPartPicker 2017-03-05 18:05 EST-0500
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9471982
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($46.88 @ OutletPC)
Memory: Patriot Viper 4 16GB (2 x 8GB) DDR4-2800 Memory  ($102.99 @ Newegg)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($78.49 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB Video Card  ($349.99 @ Newegg)
Case: Phanteks ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($89.98 @ Newegg)
Power Supply: EVGA SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1458.39
Generated by PCPartPicker 2017-03-05 21:13 EST-0500
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9472907
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($82.89 @ OutletPC)
Motherboard: MSI Z270 TOMAHAWK ATX LGA1151 Motherboard  ($139.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($99.97 @ Jet)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($48.99 @ NCIX US)
Total: $1476.80
Generated by PCPartPicker 2017-03-05 21:48 EST-0500
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/747990-first-pc-build/#findComment-9473062
