I'm building my first gaming PC, and have everything ready except the case. I've chosen three cases that I love, and I know that I'll buy one of those.
I'll use a NZXT kraken x62 cooler,  some NZXT aer RGB fansand some rgb light strips, so you can probably see what I'm going for.
Anyways, here is the cases:
Fractal Design define R5 titanium w/window
NZXT S340 black
Corsair Crystal 460x RGB
wjich one do you like the most (keep in mind, this is my first build so I want a case that is easy to build in), also, is there any other cases you think I should take a look at?
https://linustechtips.com/topic/747783-need-case/
All of these cases are easy to build in so theres no issue there. Do you like tempered glass? If yes then go for the 460x.
If not then i  recommend the s340 its a good case.
Or you know phanteks enthoo evolv hehe
CPU: R9 5900X----GPU: RX 7900 XTX ------MOBO: ROG X570E-------RAM: CORSAIR VENGANCE 32GB-------PSU: SEASONIC 1000W-------CASE: LIAN LI O11D XL ROG
https://linustechtips.com/topic/747783-need-case/#findComment-9469156
NZXT S340 black
i have an s340 and i love it, it's a great case especially for a first time builder, be careful when you're building it though as the plastic side panel scratches quite easily
https://linustechtips.com/topic/747783-need-case/#findComment-9469233
