Hi!
I have a x62 with 2x140mm fans in front set to exhaust (through a radiator). I also have 2x120mm fans as intakes.
Is that optimal? I'm planing on adding additional 120mm fan as intake, but it will ge through a radiator as well (h55 for my GPU)
Thanks!
Picture:
@Edit
I just noticed that the very back 120mm is set as exhaust on a picture... it's actually an intake now. Another one in on the roof ;)
Intel i7 3770k@4.7GHz delidded NZXT Kraken x62 Asus P8Z77-V PRO/Thunderbolt | G.Skill Ripjaws Z 16GB (2x8GB) 2400Mhz | EVGA GTX 1070 FTW
Phanteks Eclipse P400 Tempered Glass | EVGA SuperNOVA 750W P2 | 840 evo 256gb + HyperX 3k 480gb + 2 HDD (2TB) Asus Essence STX + Sennheiser HD580
AOC G2460PG 144Hz 24" + Asus VH236H 23" | Razer Blackwidow Tournament Edition Stealth | Logitech G703
Windows 10 Pro
Pixelbook 2017 (i5, 8GB, 128GB)
https://linustechtips.com/topic/747470-air-flow-question/
Well you've got it totally backwards compared to how most setups work, being intake in the front/bottom and exhaust in the top/back. I would swap everything around so that the fans on the radiator are intakes, and then make the top and rear ones exhaust.
Also where are you planning to put that additional fan and H55? The bottom?
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466079
I just swapped it again. Now I have both 120mm top as intakes (I will add 120mm h55 on the back) and two 140mm as  exhaust.  Backwards? what do you mean? It's air xD My only question was if my exhaust/intake ratio is fine.
@Edit
I guess it makes sense... damn, I will change it when I will be installing my g10
Windows 10 Pro
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466115
You either want your exhaust pushing out as much air as the intake is pulling in, or a little more intake than exhaust.
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466137
Just now, PacketAtlas said:
You either want your exhaust pushing out as much air as the intake is pulling in, or a little more exhaust than intake. I usually run 3 exhaust fans(top/back mounted), and 2 intake fans. (front mounted)
That's exactly opposite of what Jay is saying in his video. more intake and less exhaust creates positive air pressure and that's what I was going for. Also, I have dust filter on the top and no filter at front.
Windows 10 Pro
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466147
Haha I saw that I wrote that backwards, I changed it :P Positive pressure (intake>exhaust) means less dust.
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466154
Well; it depends if you have more air coming in you are bringing more air in (more air = more dust lower temps) and you will have air trying to escape through little cracks in your case and filling heatsinks with dust if not cleaned. weather with negative air pressure you have less air coming in (less air = less dust but higher temps) but you will slow down the rate that your heatsinks, fans etc, fill up with dust. if you have bigger fans you will have more air being exhausted so I would add another 120mm fan as intake which would add more noise but it would be worth it.
hope this helped.
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466359
hope this helped.
Well actually if you use filters in the front where it intakes(which most of the time you do), and you have positive pressure(more intake than exhaust)  less dust will accumulate.
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9466638
oh, ok thanks for telling me :)
https://linustechtips.com/topic/747470-air-flow-question/#findComment-9467426
