Air Flow Complications
Solved by Glennieboyyy007,
6 minutes ago, MasterLow said:i have a circular 140mm fan and a smaller square 120mm fan, the 140mm is in the middle of both radiators, do i leave that one there and use the square 120mm or do i use the 140mm??
Put the two from nzxt in the front ,as you have on your picture, and put the 140mm from noctua at the top
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases2 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
