Going from sli to one card help?
Go to solution Solved by Trevor87,
You should be good your power supply comes with the 8 pin connector cable.
Ok, im going to be upgrading my graphics card, from 2x GTX 980 SLI to 1 GTX1080 ti. I'm done with SLI when it works its great but most games SLI dos not work or no benefit or cause problems. It is just not worth it in my opinion. So the problem I see is what do I do with the power cables from the 2ed card?  I don't know what I'm doing, when I got my computer I had Canada Computers build it for me. I also notice the that Evga GTX 1080 TI  FTW3 card needs two 8-pin connectors then one on the 980 has a 6-pin and an 8-pin connector what do I do about that? Hope someone can help, Thank you for your time and have a nice day.
https://linustechtips.com/topic/746976-going-from-sli-to-one-card-help/
