Weird Problem
Go to solution Solved by TheKDub,
I'd guess it's likely a driver issue, try updating your drivers if you can, or if they're up to date, try downgrading them.
Hi all,
I just recently bought an Acer XB241H, 1080p, 144 Hz gaming monitor. The power house for that monitor is a GTX 1060. Game runs fine, not the best, have to do a little bit of tweaking. The problem starts when i quit the game. Any normal games, the pc works fine. But i mainly play Rainbow Six Siege and every time i quit the game, the monitor goes black. When i replug the DP port, the desktop is shown again. This happen almost every time i stop playing rainbow six siege. I was wondering could this be my GTX 1060 can't handle such load or is it my monitor problem or driver issue. I do have G-sync enable. (Note that every other game when i quit, works fine)
Thanks.
https://linustechtips.com/topic/746078-weird-problem/
https://linustechtips.com/topic/746078-weird-problem/#findComment-9450498
