Hey! I want to build a budget oriented content production PC and a little bit of gaming (Overwatch, CSGO , League, and a LITTLE bit of GTA 5)
my budget is $550 and its not alot but anything with a decent upgrade path would be nice.
and can you use http://pcpartpicker.com
(and try to include kinguin.net windows fee)
https://linustechtips.com/topic/745426-i-need-help/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($61.99 @ Jet)
Motherboard: Asus H110M-E/M.2 Micro ATX LGA1151 Motherboard  ($46.98 @ Newegg)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($51.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Best Buy)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($39.00 @ Amazon)
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card  ($169.98 @ Newegg)
Case: Thermaltake Versa N21 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Corsair CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $504.91
Generated by PCPartPicker 2017-02-28 19:39 EST-0500
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443058
https://pcpartpicker.com/list/Xxt8m8
Just add a case you like i think the NZXT S340 is a nice budget case i built a pc last week with one and the cable management is amazing and a good build for the price.You can also get a faster but smaller hard drive or maybe a ssd.
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443060
Total: $504.91
This is a cool build but a Dual Core?
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443062
Total: $504.91
He might have to do a BIOs update and it would be worth just spending the extra $20 on not having to deal with it. Also you can get a Seasonic S12II fo rmuch cheaper, why a 750w?? No reason. Also the SSD PLUS is really bad, a budget ADATA SSD is much better for perforamnce.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443076
Don't we all ...
/s
 CHRISTIAN MEMBER
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443080
well 4 cores cost a lot - the OP would have to wait for ryzen
Plus it is hyperthreaded. When I owned an i3-6100I played GTA V just fine, games like Rocket League easily 100+ FPS at all times, I coul even stream 720p60FPS plus I did a bit of editing and rendering. Though rendering on an i3 720p30FPS is optimal.
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443081
Just now, <Aleks> said:
AM3 platform is dead. That socket is extremely old, my old i3-6100 can outperform an FX-8350
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443085
it's a dual core with four threads, similar to an i3.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($47.92 @ Amazon)
Storage: Western Digital AV-GP 1TB 3.5" 5400RPM Internal Hard Drive  ($37.99 @ Amazon)
Video Card: Sapphire Radeon RX 480 4GB NITRO D5 OC Video Card  ($172.99 @ Newegg)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($21.98 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($46.89 @ Newegg)
Total: $564.74
Generated by PCPartPicker 2017-02-28 19:45 EST-0500
idk
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443092
Total: $564.74
This... is not worth it imo. 5400RPM drive is extremely slow and I can barely handle my 7200RPM. It'll be fine at first on a fresh install with minor programs but once stuff starts adding to it it'll be slow as hell.
Also... still needs to add in $30 for Windows 10 pushing OPs budget to far.
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443103
while that is true, the 750 watt cxm was 5 bucks more than the 450 watt so why not - the adata one was about 90 i think - and a bios update isn't that big of a deal to save 20 bucks
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443594
How is he going to do a BIOs update if he doesn't have a cpu to use with the board? HMMM?
https://linustechtips.com/topic/745426-i-need-help/#findComment-9443805
