As far as I can tell, there are infinitely many solutions for x=-2. They have to specify a y-value if they want just one angle.
In any case, I would expand sin(2t) to 2 sin(t) cos(t), and multiply both sides by r2, so you can replace r cos(t) and r sin(t) with x an y, respectively. Then it's just solve for t. But again, they need to specify a y, or there's a family of solutions.
My (first) build: i7 4790k | Noctua NH-U14S + NF-A15 | Gigabyte Z97X-SLI | G.Skill Ripjaws X 2x4GB 2133MHz CL9 | Samsung 840 EVO 120GB | Seagate 2TB SSHD | 2x MSI R9 270X TwinFrozr crossfire | Seasonic G Series 750W 80+ Gold | Asus VX238H 23" | GAMDIAS HERMES | Logitech G602 | Steelseries QcK | Windows 8.1
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9438183
Well it's implied that the y valur is the point that the two lines intersect, so the point would be (-2,y).
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9438190
Yeah but there's infinitely many such y values (see the link in my post). So you need to know which one they want, or the best you can do is leave the answer in terms of y.
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9438206
So, I figured it out.
To find the angle, you use the formula x=r*cos(theta).
x is given as -2 and r is given in the original problem. Simply plug in the two and solve for theta.
And I see your point in your first post, I forgot to mention that theta max is 2pi
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9440329
Yeahhhh you're gonna get a transcendental equation for theta if you try that. Unless they further specify a y or an r or something, then it's not going to be solvable algebraically. That's a pretty weird question for a Calc BC class. Can you post a picture of the problem or something?
Side note: if you want more fun with transcendental equations, try finding all 3 solutions to the equation x2 = 2x. Two of the solutions are more or less obvious, but the third is tricky!
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9440767
I feel like I'm missing something then from my original explanation. My classmate got 2.786 as the solution for θ. But they used the same formula I did, I'm not sure if I missed a step or something.
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9441186
That's the correct answer, but there's just no closed form for that solution (you know, something like "sqrt(arccos(1/3))"). You'll have to get the answer numerically. If that's what the question is asking, then you're golden (as long as you know some numerical method to get the answer). Otherwise, you're shit outta luck. That is, unless I'm missing something too. @Dash Lambda, care to comment?
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9441310
You're not missing anything.
The polar function contains the component r=θ, which cannot be solved explicitly for θ in terms of x or y. Best way to approach it is either numerically or graphically, I'd personally just do it graphically. (Specifically by plotting the function for x you guys already got, x=(θ+sin(2θ))cos(θ).)
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/744981-bc-calculus-help/#findComment-9442087
