I am thinking of buying an R9 Fury, and I know how loud its gonna get. However, would it be a good idea to move it away and use my potato PC to stream off of it? First off, I could confuse the hell outta my friends, and also it would be pretty awesome :). Are there any issues with steam streaming? I plan to play competitive games like CSGO.
Edit: it took 8 minutes to start up steam on my potato
https://linustechtips.com/topic/744971-perfectly-silent-build/
It takes some amount of bandwidth , you could try passively cooled parts and noctua industrial fans if you want to be 100% silent, your ceiling fan would probably be louder
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/744971-perfectly-silent-build/#findComment-9438074
it's very hard to get 100% silence at load, but at idle, it's pretty easy
if you want 100% silence at load, you need to do what linus did, and put your PC in a different room and move everything over thunderbolt.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/744971-perfectly-silent-build/#findComment-9438092
