Thermal Compound
Go to solution Solved by Guest,
yeah it will be enough
I am planning a build for this summer and I will be using the Corsair h100i v2 AIO cooler. It has pre-applied thermal paste, and I am wondering if that will suffice. Is it worth spending the extra few minutes to clean off the pre-applied stuff and spend the extra few dollars for thermal paste or will the stuff that it has pre-applied work alright?
https://linustechtips.com/topic/744945-thermal-compound/
