I'm playing overwatch and it says my temp is 65-70c in my in game temp counter I changed my graphics card (from a gtx 1050 ((red and black long one not sure specific)) to a rx 470 armour oc edition)  it used to be 60 c is it. because of my new graphics card?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/744935-temps-for-which-part/
use msi afterburner with OSD to measure both cpu and gpu temps in game
https://linustechtips.com/topic/744935-temps-for-which-part/#findComment-9437746
4 minutes ago, lilbman said:
Use something like Intel XTU.  That seems to be a bit more reliable to me.
6 minutes ago, M.Yurizaki said:
What temperature is this? If it's the GPU, then sure. If it's the CPU then that's odd.
RAM: 32gb ddr3
https://linustechtips.com/topic/744935-temps-for-which-part/#findComment-9437747
7 minutes ago, M.Yurizaki said:
We're going to need it from something that actually tells us what it is. Like from HWMonitor, MSI Afterburner, or something.
that's my cpu that hw said my cpu is 27 c and graphics card is 69 c
RAM: 32gb ddr3
https://linustechtips.com/topic/744935-temps-for-which-part/#findComment-9437819
Then that's fine. You have a new graphics card, it isn't going to behave like your last one.
https://linustechtips.com/topic/744935-temps-for-which-part/#findComment-9437837
Overwatch reading is GPU temps. It seems drastic because Pascal GPUs don't tend to get hot at all, even when they're overclocked. Those temps are nothing to worry about. You can use Radeon chill to use less power while you're in queue.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/744935-temps-for-which-part/#findComment-9437864
