Help me!!! (compatibility) FIRST TIME
Go to solution Solved by Herman Mcpootis,
yes, but don't get a 6600k with a h110 mobo. either go with a z170 mobo or get an i7 6700/7700 instead(or wait for ryzen).
CPU = Intel core i5-6600k 3,5GHz Quad-Core Processor
CPU Cooler = CRYORIG H7 49.0 CFM CPU Cooler
Motherboard = MSI H110I Pro AC Mini ITX LGA1151 Motherboard
Memory = Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4 - 2133 Memory
Storage = Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive
Video Card = Zotac GeForce GTX 1070 8GB AMP! Edition Video Card
Case = Phanteks Enthoo EVOLV ITX Mini ITX Tower Case
Power Supply = Corsair CXM 550W 80+ Bronze Certified Semi Modular ATX Power Supply
Case Fan = Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm Fans
Monitor = BenQ GL2760H 27.0" 1920x1080 60Hz Monitor
Keyboard = Corsair Vengeance K70 Wired Gaming Keyboard
Just as the title says, I need help and its my first time making a pc. Are these parts compatible with each other?
https://linustechtips.com/topic/744929-help-me-compatibility-first-time/
So I can just go get the h110 board along with the i7 6700 or would it be better to just go with the z170 with the 6600k?
h110 and the i7 would be a better choice imo.
I would like inquire once more...
If the ryzen is out, should I buy that instead, if so which type, and will it be compatible with the specs I gave before?
If you have the luxury of time I would say wait and see how Ryzen pans out.. sadly I do not have this option >.<
