help with m.2 storage struggles
Joppert
Hey guys!
So i found this deal on a special ssd.
It's a Transcend SSD: 240GB JetDrive 725.
spects:
Interface SATA III 6Gb/s
Capacity 240GB, 480GB, 960GB
Flash Type Synchronous MLC
And I have this motherboard.
Gigabyte GA-Z97X-SLI --> https://pcpartpicker.com/product/7jPfrH/gigabyte-motherboard-gaz97xsli
spects:
M.2 PCIe connector
(Socket 3, M key, type 2242/2260/2280 SATA & PCIe SSD support)
My question is will these two work together?
And can i boot from this ssd?
As above you just need to connect it with a SATA data and power cable and it should work fine. And yes you can boot from it if you install windows on it.
