Help with cables
Go to solution Solved by Guest,
Look at your motherboard manual, there will be a diagram
Hi everyone,
I'm building a game pc and have all the components. I was installing all the parts when I found these cables. They are from my case. Where do they need to get plugged in on the motherboard?
Any other tips with building will also be appreciated. :D
Thanks in advance!
My build:
CPU: intel core i5-7600K
CPU cooler: Cryorig h7
Motherboard: msi z270 gaming carbon
RAM: corsair vengeance lpx 16GB 3200MHz
HDD & SSD: wd elements red 2TB & Samsung 960 evo 500GB (pci m.2 SSD)
GPU: msi gtx 1070 armor 8GB OC
PSU: corsair RM550x
Case: NZXT H440 RAZER edition
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/743516-help-with-cables/
check your manual for that, there is a pin array on the bottom of the board where they need to go in in a particular order.
called front panel connectors
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/743516-help-with-cables/#findComment-9422312
ah, front panel connectors - they're always so tedious.
It should be near the middle on the very bottom of your board, check your manual for the layout
the power and reset headers don't matter which way you put it in (+,-).
Woo!
https://linustechtips.com/topic/743516-help-with-cables/#findComment-9422320
With your motherboard you also got user guide.
Find something like this in your user guide:
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/743516-help-with-cables/#findComment-9422351
