Hi! I just finished a build for my 11-year-old cousin, as his first gaming PC. Specs, to those interested:
i5 2500K@4.2GHz on air
AsRock Z68 Extreme3 Gen3
8GB Corsair Vengeance DDR3 1600mhz
Gigabyte G1 Gaming GTX 960
1.5 terabyte HDD
Corsair HX650 modular PSU
The point of this post is to try and identify the case this PC is in. Its quite tall, at 54,5cm. It has a removable dust filter on the front, a sturdy "shelf" for the PSU up top and some plastic protecting the power cables being run from the top (pictures attached). Only two points for mounting fans, in the front and back of the case. A seemingly removable HDD caddy, though can't confirm. The QC stamps on it date back to 2004.
Thanks in advance!
https://linustechtips.com/topic/743498-help-in-identifying-a-pc-case/
Looks like some generic OEM case if you ask me.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Sure does, but has a lot of features none of the OEM cases I've seen don't have.
5 minutes ago, Lolcrokn said:
can you not google with images ? try doing that
Google seems to only recognize the room around the case, so no help there. Trying to look for some serial numbers, see if they get me anywhere.
