gpu or cpu temps? I think newer versions of msi afterburner can monitor the temps of both the cpu and gpu...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/743392-how-to-check-temps/#findComment-9421252
Just now, TheTurtleKing said:
I'd prefer both.
Are you implying I have to install more programs?
darn :/
As far as I know there isnt anything built into windows to check temps.
https://linustechtips.com/topic/743392-how-to-check-temps/#findComment-9421262
You can use hwinfo for cpu and other (on my laptop it doesnt show the gpu) but it might show in yours, just extract it and click on "sensors only". This program is very light 4mb soo not a huge problem and this is for 64 bit version. you can download it from here:https://www.fosshub.com/HWiNFO.html for 32bit
hw64_541_3040.zip
https://linustechtips.com/topic/743392-how-to-check-temps/#findComment-9429563
I use MSI Afterburner on my main pc and on my laptop, it works great for CPU and GPU.
Here's a link: https://www.msi.com/page/afterburner
i7 7700k @ 5.0GHz | GTX 1070 Founders | Vengeance LPX 16GB | Asus STRIX Z270F
-  Logitech G930 7.1 | Corsair K70 Lux RGB | Mad Catz RAT5 | Acer 4K 24" K242HQK | Sony 31" HD  -
https://linustechtips.com/topic/743392-how-to-check-temps/#findComment-9429599
3 minutes ago, Ultra_Man52 said:
Personally, the program I prefer is Speccy. I've never seen anything wrong with it and has a very simple layout. The free version is fine, but make sure to not install CCleaner on the download. https://www.piriform.com/speccy
ahh thank you.
much much much better.
https://linustechtips.com/topic/743392-how-to-check-temps/#findComment-9429685
