Wireless/Blu-tooth Earbud Help
Go to solution Solved by Doramius,
2 minutes ago, Drake10114 said:
What blue-tooth dongle would you be refering to? Something that plugs in via usb and had a bluetooth connection on it?
Correct. Something like the ASUS USB-BT400 would be fine.  there are others that work just as good and probably cheaper.
Hello,
Figure'd I'd ask people here, before I just search Amazon and find a random pair to statisfy my needs...
I'm looking for a wireless headset that connects via 3.5mm audio jack to a PC.
Not looking for anything high end, just something, I can use to listen to music while at work.
Currently I have a basic Samsung wired earbud pair, but I'm finding that the cable get's in the way of my keyboard.
So does anyone have any brand recommendations, or know if such a product even exists.
Blu-tooth, may work, but idk if my work PC has blu-tooth on it...
Budget will be around $30 - $40 CAD.
Edit: Just realized I posted this into the wrong sub-forum, I apologize. If a mod or Admin could move it for me, that would be appreciated.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/743133-wirelessblu-tooth-earbud-help/
Why would you be looking for Bluetooth based options if you're just going to be connecting them via 3.5mm?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
More thought that there was such a device that had a 3.5mm transmitter and a receiver in the earbuds themselves, but I didn't realize that practically all wireless headsets are connected wirelessly via bluetooth.
Agreed.  if you want bluetooth and your system doesn't have bluetooth, the dongles are pretty cheap.  get the dongle, and get a headset.
Just get something like a 3.5mm extension cable.
Main System: Phobos
Would run into the same issue now, where the cable runs over my keyboard, unless you mean extend, the cable, and run it around/under my keyboard?
They're USB dongles that have a Bluetooth chip inside them.
Main System: Phobos
That's what I meant.
Main System: Phobos
Ahh okay, didn't think of that, thanks, that may actually work then.
Does it matter how heavy the keyboard is that's ontop of the cable?
Using a Blackwidow Chroma, and it's quite hefty for a cable.
Thanks for the help everyone, I'll look into both options, either 1 should be good.
