I need to figure out how to set up Microsoft visual programing language to run both the 2 motors and run of an xbox controller. I am running Eddie v1.3 made by parallax.
A smile goes much farther than the person it's meant for.
First impressions are important, it sets the stage for respect.
"If you don't know every word you don't know it!"- SGM McCray
https://linustechtips.com/topic/742749-eddie-robot-help/
I need specifics here. This is urgent and both YouTube and google are not helping. I already told you what programming language I am using.
Just now, gtx1060=value said:
just start a project in whatever language you're using - if it's not supported, just install a package - no big deal
https://linustechtips.com/topic/742749-eddie-robot-help/#findComment-9413736
wait, you dont want to use visual studio to edit the code, are you using visual basic for the programming?
https://linustechtips.com/topic/742749-eddie-robot-help/#findComment-9413745
The program I am using is called Microsoft Visual Programming Language.
https://linustechtips.com/topic/742749-eddie-robot-help/#findComment-9413751
