So using FRAPS my major bottleneck is my HDD. I was thinking about getting a dedicated drive for FRAPS recordings. I'm considering a fast HDD (Something like a velociraptor) or maybe an SSD. If i was too choose an SSD do you think writing such large files to it often would severely shorten it's life span?
What drive would you guys suggest be it HDD or SSD?
Simple Stryker (Now Finished  ;) )
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/
See if you can find one of those seagate SSHD
Its got a 8Gb SSD cache to the HDD which is like however many terabytes of storage :)
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1017381
i have a seagate baracuda and it is no faster recording to my ssd. hdd's are plenty fast enough.
Not from what i have tested. With my HDD i get bad slowdows and my average FPS is pretty poor. With my SSD however my average FPS is only a little lower than without FRAPS and i get no slowdowns.
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1017384
I have no problems at all with recording to a hard drive. i'd check other parts of your system..
Well i have a 2TB Green drive that i could try but i can only imagine it would be way slower
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1017420
Why do you use fraps and not dxtory? It makes smaller files/less performance hit and is generally better, so the hdd requirements should be less
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1018122
Use OBS  or if you must have FAPS then use a HDD I don't think you need a SSD or an SSHD for Fraps maybe for DxTory but not for FAPS.
I've tried DxTory and my recordings were only around 10-15 FPS. My gameplay was fine whilst recording so i'm assuming my HDD was the bottleneck again.
I will try OBS today and see how it performs.
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020367
did you tweak the settings in dxtory at all? cause if not that explains it, if you want i can give you what i use and maybe try it then.
I switched from fraps to dxtory when i found out how to properly use it
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020460
A good drive would be a seagate sv35 its designed for video survalence and dvr usage both of whoch are close to streaming in the way they utilize a drive.
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020558
I tried all the codecs and changed the settings that i understood but it didn't seem to change much
Thank you for your suggestion, i will look into it :)
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020908
Did you increase the amount of cores dxtory can use? in default its set to 1 which i find is not enough
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020920
Yeah i set it to 4. I'm starting to think my HDD doesn't like this type of media being copied to it. It does just fine in speed tests and it doesn't have any bad sectors. It's the only explanation i can give for my poor performance with this drive
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020932
Another thing, is the game on the same HDD as the one you are recording to? if yes that explains it, if not im out of ideas
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020937
Nope it isn't. I put most of my games on my SSD. I'm not sure how to explain it either.
The Terrible HP
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020946
These drives also regularly go on sale on newegg I just picked a 3TB up as my games drive for $120 after promo code and at the same time the 1TB was on sale for $65. If you going to buy one not on sale the 2TB is the best price and I currently have one of those in my HTPC/Server as the recording and games drive. There are only like a couple games on it. I would have put on the OS SSD but its only 40gb and Win7x64 takes up most of that and and after the needed programs for HTPC and Sever stuff there is only room for about one game. But with no space left both windows and the SSD wont be the happiest if you know what I mean.
Also the SV35 series has blazing performance because they have a 1TB per platter density so if you want speed pick up the 1TB drive as it only has one platter. Besides that they are considered entry level enterprise drives so you podo get a better warranty than a standard consumer one.
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020954
I've always been confused by people commenting on fraps performance. If you have a secondary drive than what the game is on I don't understand why Fraps (and from my tests fraps hasn't) made a difference in fps. With a sperate diver all over, it does it record the footage and doesn't slow anything down. It made 0 difference to what the game was outputting in fps. There was no 10-20% reduction. There has always been a 0% reduction as long as you record on a secondary drive as what the game is on.
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1020971
If you use some sort of compression it will impact your frame rate even if you record to a different drive. I mean you might be able to get around this if you have a 6 core cpu as you could lock the game to as many cores at it would use then lock FRAPS and the encoder to the other cores.
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1021560
Hey dude, I highly suggest using DXtory, also look up the video on how to record 1080p video but also cutting it down in size using the lagarith loseless codec, saved me a load of times.
Processing video through adobe premier or sony vegas will also cut down your end video in size a lot.
I have a dedicated hard drive for recording to, and the performance is very noticeable, especially if you are running games off the same drive. I just use a general storage seagate 7200 1TB drive, (69 bucks or whatever) and it does the job perfectly.
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1030953
For the drive as I said before look at the Seagate SV35 series they are usually the same price if not much more than their normal drive.
https://linustechtips.com/topic/74255-dedicated-drive-for-fraps/#findComment-1031970
