36 minutes ago, cj09beira said:
use wattman, i used it to get mine all the way too 1440, although i am using 1400 now
ok maybe a dumb question. but right now i have it tuned into 1450. its running fine at 62c but it keeps throttling down to like 1377 or even around 1310. how can i get a more steady clock?
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9407558
I don't see why afterburner is giving you issues. I used to use it. Make sure you have the voltage unlocked in afterburner settings. If it still doesn't work, use Trixx.
DON'T USE WATTMAN
If you are throttling, check your temps. You might also not have enough voltage to sustain those clocks and need to add more.
Edited by ivan134
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9409137
DON'T USE WATTMAN
If you are throttling, check your temps. You might also not have enough vintage to sustain those clocks and need to add more.
why shouldn't i use wattman? also i've used afterburner on every card up until this one, for some reason the asus strix 480 just doesn't want to play with it.
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9409143
Wattman is garbage software that is very prone to crashes. Like I said, use Trixx if afterburner is giving you issues.
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9409150
well its been working fine for me so far, but if it gives me any issues ill checck out trixx. im a little relucctant since it seems like this card doesnt want to let anything non proprietary mess with it.
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9409190
Do eet. If you check out buildzoid's channel, he used trixx when he was OCing his strix 480.
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9409199
On 2/22/2017 at 2:08 PM, Juggern0ttt said:
So I've got this shiny new rx 480 strix graphics card. but i can only seem to get any type of tuning on it done with gpu tweak, which caps an oc off at 1400mhz.... this is wildly annoying. are there any other ways to OC this card?
I overclocked my Strix using Afterburner. I was having the same issue with gpu tweak and couldn't get past 1400mhz. I can reach 1430mhz with Afterburner.
Lian-li O11-Dynamic | i7-11700K |  MSI Z590 MAG Tomahawk | 64gb Ripjaws 3200MHz | 1tb Nvme SSD + 6tb HDD RAID | Corsair H115i Cooler | EVGA 850BQ PSU | RTX 3080ti TUF | LG C2 65" & Acer Nitro XV340CK Monitor
https://linustechtips.com/topic/742164-strix-rx-480-oc-help/#findComment-9425250
