Was doing construction work at home and some pretty heavy dust (i think its called filler dust in english) managed to get in my pc (couldnt air blast it out it was sticking to the fans too hard) it looks like i will need to disassemble the fans to get it out.
I have a zotac gtx 970 and a cooler master 212 hyper evo would appreciate some help on what i should use to clean it. If you could point me to a disassembly guide or give me a basic guide would be greatly appreciated .
Sorry for bad engrish.
https://linustechtips.com/topic/742133-pc-fan-cleaning/
damp (NOT WET) cloth if you cannot get it clean with compressed air.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/742133-pc-fan-cleaning/#findComment-9406848
https://linustechtips.com/topic/742133-pc-fan-cleaning/#findComment-9407054
Try using a soft toothbrush :) Works really really well...
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/742133-pc-fan-cleaning/#findComment-9416858
