I have a 1TB hard drive that i am replacing with a new 1TB hard drive i want to move all my data to the new drive but all i can find on ways to do this are companies saying "use our software" or that i would need another drive to create an image on install the new drive then import the image is there a better way. what I thought about doing was to setup a raid1 then after it builds the raid remove the old drive and remove raid would that work.
https://linustechtips.com/topic/742093-need-help-cloning-a-drive/
Why not just download some freeware, or just copy paste files?
(unless the HDD is your boot drive, in which case you cant copy/paste)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
2 minutes ago, crimsonier said:
it is my boot drive its the only drive i have in my system
Clonezilla; http://clonezilla.org/show-live-doc-content.php?topic=clonezilla-live/doc/03_Disk_to_disk_clone
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Quote me next time
Anyway:
http://www.pcmag.com/article2/0,2817,2421302,00.asp
While many find it worthwhile to pay for the convenience and ease of use offered by a for-purchase program, there are a few popular free alternatives that may do the job just as well, such as Macrium Reflect Free, ShadowCopy, Clonezilla, and EaseUS Todo Backup Free.
Laptop:
6 minutes ago, RadiatingLight said:
Quote me next time
Anyway:
which of those would you recommend me use vorticalbox recommended clonezilla but what would you recommend
