So my dad has an old Dell Insperon 530, and we wants a new video card for it. The biggest problem is that he has a 300W power supply.
1) Will a PCIE 16x slot be able to accept PCIE3 16x slot cards
2) What graphics cards will run on 300W PSU
 He doesn't need a super fast one, just one that will run like marvel heroes, SWTOR, and other not demanding FTP games on low @1366x768
Oh yeah it's also a Dell power supply, no idea how efficient it is.......
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/
1) yes
2) a 7790 would be a good option, it only uses like 80-90watts at max.
current system:  i5 2500k @4.5ghz cooled by antec 620 - asrock z77 extreme 4 - 8gb corsair RAM - MSI Twin Frorz 7950 in crossfire - XFX 850w  - Fractal design R4 - samsung 840 120gb ssd - 500gb wd blue hdd - 1440p korean qnix monitor (love it!)
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/#findComment-1016721
Are you saying it literally uses 0W? That makes no sense.....
No the pcie connection can deliver up to 75w I think
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/#findComment-1016744
^ This. The PCIe Lane can support up to 75w of Power.
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/#findComment-1016784
Is a 7790 really necessary for 1366x768?
I doubt the 300W power supply has a 6-pin PCI-E plug.  The 7790 requires a seperate 6-pin plug.  You can get adapters that use 1 or 2 molex to convert to a 6-pin, but In my opinion, if the PSU doesn't have one, then it wasn't meant for one.  kuzimins had it right with the 7750.  It's probably one of the best cards out right now that doesn't require an addition power plug.  I would imagine that the power supply has pretty low amps on the 12V rail, which would mean that the card will be pushing that power supply pretty hard.  7750's are around 100$ new (newegg) and 75$ used on ebay.  If he does want to upgrade the power supply, newegg has a corsair 430w for 20$ after rebate with free shipping which could power any card that requires one 6-pin plug.  Hopefully this helps.
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/#findComment-1016919
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
https://linustechtips.com/topic/74206-cheap-gpu-for-old-system/#findComment-1017773
