G4560 Compatability help
Solved by G27Racer_188,
1 minute ago, Redliquid said:how would i go on about doing that?
Well I'm sorry to disappoint you but it seems that asus didn't release a bios update for that motherboard for kaby lake cpus. G4560 is not listed as compatible with any version of the bios.
So you have three options now: get a compatible cpu with the current motherboard, get new motherboard that supports that cpu, or third option is to try to find someone with a skylake cpu an update the bios to the newest version and maybe, but just maybe (no guarantees) the board will work with the newer cpu.
