9 minutes ago, catcontrol_98 said:
Is the ENERMAX ETS-T40F-BK cooler compatible with my NZXT Phantom 530 series case, EVGA Classified Z270 case, and G.Skill value ram?
Yes, that is basically a clone of the 212 EVO, the cooler height is 162 mm, while the NZXT Phantom 530 supports up to 183 mm
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/741789-cooler-clearance/#findComment-9403361
