Ok so first i'd light to make clear, yes it's expensive for what's in it because i crammed a lot in it. There, now that that's out of the way...
Sorry for the bad quality, lighting in my room sucks -__-
Parts List:
https://pcpartpicker.com/user/OGKingFox/saved/M8KFf7
I started out with a PC i bought on ebay for $170 that was pretty sketchy. As you can imagine, it didn't have much but a AMD Athlon X4 640 cpu and a Radeon HD4830 graphics card and everything else was pretty basic.  Replaced it one part at a time and ended up with the PC you see below. It's an ongoing project of mine and will be for quite a while as i still have a lot i need to do.
I used the NZXT S340 Elite as the case due to it being a reasonable price and glass window, plus I've used it before and just absolutely loved it (used it when it was just the acrylic window). I tinted the window using 20% window tint. Albeit a little dark, the Hue+ on the inside make it look pretty good. I may replace the tint with either 35% or 50%. Probably 50%....
Also i'd like to note than i'm currently renting the RX 480 from Cutting Edge Gamer due to monthly payments only being $35 a month. I plan on using buyout option to be able to keep it (basically the terms is for 12 month but if i pay an extra month card is mine to keep). Not bad i think but it does come out overpriced, but i'm not worried about it. Didn't break the bank initially to buy it so I'm happy :3
lemme know of any suggestions or minor tweaks you'd like to see! (The white LED fans are being replaced soon, so keep that in mind :P)
My Build:
Processor: Intel Core i5 4590 @ 3.3ghz
Motherboard: ASRock Z97 Fatal1ty Killer
Graphics: Sapphite Nitro+ OC RX 480 8GB
Memory: 8gb Kingston HyperX Fury 1866mhz RAM (2x4gb)
Cooling: Swiftech H220-X2
Case: NZXT S340 Elite Tempered Glass
Power Supply: EVGA GS650 650W
Lighting: NZXT Hue+
Extensions: Phanteks Black/Red Extensions
https://linustechtips.com/topic/741705-project-foxtrot/
With the amount you are paying for that GPU, you could've easily gotten a 4790K and Rx480... you realize you have a locked CPU on a Z-series board under water, which makes no sense.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/741705-project-foxtrot/#findComment-9402253
i fully understand what i could have gotten but I rented to save the money up front and to help build credit.
and yes i know the CPU is locked. I went ahead and did Z series and liquid cooling because i only paid like $150 for the 4590. It's called planning ahead :P
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/741705-project-foxtrot/#findComment-9402265
Understandable.
Your signature needs major updating lol
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/741705-project-foxtrot/#findComment-9402273
5 minutes ago, Shiv78 said:
Understandable.
Yup, currently trying to figure it out :L
edit: just found it, updating it now lol
Edit2: @Shiv78 fixed it :D
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/741705-project-foxtrot/#findComment-9402280
