Case problems HELP!
Go to solution Solved by Guest,
Well my CiT Spectre White just set on fire, and melted the cables, so i need a case really fast, do any of you have a cool full tower case that costs less than £50, It needs to be full tower or just fit the Asus m5a97 le r2 with a cooler master 212 evo and a msi radeon 470 gmaing x. Please help.
Thanks in advance.
https://linustechtips.com/topic/741636-case-problems-help/
2 minutes ago, RKRiley said:
How did your case set on fire.. sure it wasn't the power supply?
The case has two fan controller integrated into the front panel, the low quality plastic slide of making the cables touch and melt resulting in burning.
https://linustechtips.com/topic/741636-case-problems-help/#findComment-9401267
3 minutes ago, deXxterlab97 said:
Thanks, the masterbox looks like it has alot of cable management and will look good with my setup.
https://linustechtips.com/topic/741636-case-problems-help/#findComment-9401286
