Hi guys,
looking to upgrade my current laptop to a more advanced laptop.
Price range is about £800 ($993)
I have found 2 laptops that look good for my needs (Dota, Battlefield, Rust.)
https://www.msi.com/Laptop/GP62-6QF-Leopard-Pro.html#hero-overview
https://www.msi.com/Laptop/GL72-7QF.html#hero-overview
SSD needed with 1/2TB HDD, and a good battery life.
If anyone can help that would be great,
Thanks,
Dec/
Cpu Intel Core i7 (3770) 3.4GHz Qaud Core - MB MSI Intel B75MA-P45 - RAM Hypertec Hyperam 32GB - GPU EVGA Nvidia GTX 980 ti 8GB SSC - Case Cooler Master K-Series K380 Storage SSD 240GB Sandisk WD 1TB Caviar Blue - PSU EVGA 600W Bronze - Display BENQ 22' GL2450 - Cooling Cooler Master Hyper TX3 Evo
https://linustechtips.com/topic/741461-msi-laptops-help/
21 minutes ago, Dec_Shaw said:
Hi guys,
Thanks,
Dec/
What's your current laptop specs?
I will recommend gtx 1050 laptops.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399269
Intel® Core™ i5 5200u 2.7ghz
8GB Ram
1TB HDD
Intel integrated graphics
hence why I want an upgrade is was mainly for work at university, but I like to play games, and I struggle to play Dota 2 on this laptop.
Thanks for the reply.
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399284
8GB Ram
1TB HDD
If your goal is to play Dota 2, here's my opinion:
For 768p u need 6200u/7200u + 940MX/950m(max settings)
For 1080p u need quad core CPU + 960m or 1050/1050ti(max settings)
Desktop specs:
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399311
For 768p u need 6200u/7200u and 940MX/950m(for max settings)
For 1080p u need quad core CPU and 960m/1050/1050ti
Have you got any idea what laptops there are that would suit me?
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399319
Desktop specs:
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399369
Do you have any other requirements like ips screen, black and red theme etc?
Desktop specs:
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399373
Do you have any requirements like need a ssd, ips screen etc?
1080p good refresh rate, don't really need a DVD Drive. and good battery life is needed.
Thanks for your help
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399376
Just now, Dec_Shaw said:
good refresh rate
I think you need to increase your budget if you need any display over 60hz
The Dell 7567 has a good battery, more than 10 hours on wifi according to notebookcheck: http://www.notebookcheck.net/Dell-Inspiron-15-7000-7567-Gaming-Notebook-Review.196454.0.html
However it's display is mediocre.
Desktop specs:
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399385
Welcome!
Desktop specs:
https://linustechtips.com/topic/741461-msi-laptops-help/#findComment-9399389
