I am intending very soon to buy a new SSD to use as my boot drive. I am basically looking for the fastest SSD in the 240-256gb range that goes for anything between 120-180 euros. You can check www.1a.lv to see my local pricing. Right now I am leaning towards the CORSAIR FORCE SERIES MP500 240GB, but if someone can recommend something else, please do. Thank you in advance!
CPU: Ryzen 7 3700X
CPU Cooler: be quiet! Pure Rock
GPU: Gigabyte RTX 2070 Super Windforce OC 3X
Motherboard: MSI B450 GAMING PLUS MAX
RAM: 4x8GB (32GB) Kingston HyperX Fury Black RGB 3200MHz
PSU: BitFenix Whisper M 650W
Case: NZXT H440
SSD: 500GB Samsung 850 EVO (Boot Drive); 1TB Samsung 970 EVO (Primary Game Drive). 1,5TB total SSD storage.
HDD: 3TB Seagate Barracuda 7200RPM; 4TB Seagate Barracuda 7200RPM. 7TB total HDD storage.
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398876
10 minutes ago, legacy99 said:
Hmm those are SATA drives, though. Would I not see a big difference in performance between those and PCIe/NVME drives?
CPU: Ryzen 7 3700X
Case: NZXT H440
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398892
you never specified form factor....
Community Standards
"Beast Mode"
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398896
for boot times, most of the slowness comes from the BIOS loading up.. not from the drive with an SSD. The real benefit with an NVME SSD over Sata will be with programs that are loaded on it
Community Standards
"Beast Mode"
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398901
Just get one from a good brand "Intel,kinston,corsair,samsung"
That suits your needs
Tag me if you need me :D
Desktop:                                       Laptop:
CPU - i7-4790k                            CPU: I7 7700HQ
GPU - Inno3D 1080TI                  GPU: 1060
Mobo - Gigabyte Z97X-SLI          Memory: 16 GB
Memory - 32 GB DDR3                Storage: 1256GB
Storage - 11 TB
Phone: ONEPLUS 6 128GB
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398940
Yeah, my bad I thought it was clear from the 'fastest' but I realize that was too ambigous. And yeah I meant performance with programs obviously I am not getting an ssd just to load windows. Sorry for not being clear about things.
CPU: Ryzen 7 3700X
Case: NZXT H440
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9398942
Community Standards
"Beast Mode"
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9399024
2 minutes ago, legacy99 said:
Is there a real and meaningful difference between a fast sata drive and a nvme/m.2 drive? In terms of loading times in games and programs.
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9399032
For program load times yes, Sata is saturated at 550ish Mbps bandwidth where as NVMe is much much faster. Some of the older m.2 drives are actually just Sata, so they do the same as a traditional connection. Now this does not take into consideration any program that will need to reach out to the internet for connectivity or anything like that. This will only affect programs 100% internal to the machine/drive itself.
Drive IOPS (4kB R/W) Max Sequential Read / Write Rate
Spinning disk ~100 ~ 200 MB/Sec
SATA SSD 99,000 Read
18,000 Write
520 MB/Sec Read
475 MB/Sec Write
NVMe SSD 430,000 Read
  50,000 Write
2600 MB/Sec Read
1000 MB/sec write
 Table 1: IOPS and max throughput yield enormous improvements.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9399045
18,000 Write
520 MB/Sec Read
475 MB/Sec Write
  50,000 Write
2600 MB/Sec Read
1000 MB/sec write
Thanks!
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9399088
There is very little real world performance difference between SATA and NVMe.  Unless you're working with huge files (not Windows or programs), what matters is how fast it reads tiny files.  There is usually about a 30% increase in 4k read speeds for double the price.
So save yourself some money and get a SATA one.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/741432-help-in-picking-an-ssd/#findComment-9399101
