hey guys!
so i just turned off my pc and then turned it on again cuz i forgot to write an email. Now what happened was, was that my pc just wouldnt turn on, switching off PSU, etc. waiting and turning on didnt work. I made sure the power switch was properly in these small pins, made sure that it doesnt have dust too. nothing happened. Now then i took a screwdriver and put it on the pins and the PC started properly. This is definetely a case power switch failure. Now I would need to know what to do. Are there any explicit power switches, i could theoratically route it through the back next to the gpu to the top of the mobo. The problem is, that i cant find any of these on amazon.de.
I would be buying off of amazon.de, if you guys find one there or have a good solution, please let me know as fast as possible, i cant always takr the case off and turn the pc on that :/
thanks in advance,
Tiwaz
https://linustechtips.com/topic/741137-case-power-switch-died/
Would be a lot easier to help if you told us which case you have.... ;)
But nevertheless your best bet is most likely to contact the manufacturor to hear if they can sell you a new one,  or free of charge if you are still under warranty.  Germany has pretty god customer laws so...  Give it a go.
https://linustechtips.com/topic/741137-case-power-switch-died/#findComment-9395333
nzxt S340
I am not german :P
https://linustechtips.com/topic/741137-case-power-switch-died/#findComment-9399657
2 minutes ago, Tiwaz said:
nzxt S340
I am not german :P
Asgard... That would most likely put you in Denmark, Norway or Sweden with the off chance Finland ;) And amazon.de is the closest amazon to those countries.
Your best chance is to contact NZXT directly regarding a new power switch.
https://www.nzxt.com/users/login#acc-submit-ticket
https://linustechtips.com/topic/741137-case-power-switch-died/#findComment-9399675
well, i already ordered a replacement switch for 5€ before i had read your post x)
but thanks anyways ;)
https://linustechtips.com/topic/741137-case-power-switch-died/#findComment-9412854
No problem. Hope it will be an easy replacement. Did you order it from NZXT directly?
https://linustechtips.com/topic/741137-case-power-switch-died/#findComment-9412879
