I have a raid 10 array in my PC (2 barracudas 1WD Blue and a WD green). The green drive is much slower thaan the others (around 70MB read) could it be bottlenecking my array or are these numbers normal?
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/
Seriously you have different type drives in the same RAID?  Not good practice.
What model are the barracudas?
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393440
I have different drives because they are different batches and the barracudas are both the 7200rpm models one is new the other is about a year old
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393442
still not good practice.
Anyway ....  this is the stats for my WD Blacks in RAID1 (not 10) so you numbers are not bad but not great either for slower+stripped.
Man - i forgot just how SLOOOOWWWWWW     HDDs were.
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393451
2 minutes ago, zMeul said:
a RAID array is as fast as the slowest drive
putting WD Greens in RAID is a really really horrible idea
yea figured as much (only spare drive I had). how simple is it to swap out the drive, I don't mind waiting for the raid to rebuild?
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393453
must be that crap drive, payday needs to hurry up so I can get my reds and blacks
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393455
if you really trust the RAID software, just "fail" the drive (pull it out) and plug the new one in.   Reboot require if not hot-pluggable.   rebuild the array - and leave the computer idle for as many hours / days as that takes.
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393461
I would back-up everything the rebuild it from scratch with proper drives
ok, I'm getting some wd blacks on payday and some reds for my server. I'll rebuild the raid after my server is running
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393462
If you have a payday coming up, get SSD's instead.  much better speed.
My RAID0 of NVMe SSD's:
You are correct, i am only including that to show off.
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393468
1 minute ago, zMeul said:
I would get Reds for RAID, not blacks
I'm using reds in my server (which backups my pc nightly) the raid in my pc is just for unimportant files and Powah!!!!
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393469
woa, I dont think I can afford enough ssd's for a 2tb raid
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393478
4 minutes ago, zMeul said:
then why RAID10?
For better iops, i run a few vm's and I was told raid 10 was good for that
PSU tier list-
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9393481
11 hours ago, Matt_98 said:
-snip-
I would agree with everyone else, get a SSD for the VMs.
As for RAID10, I had four WD 4TB Reds in RAID10, that was around 350 sequential (I forgot the random though) for both read / write. I have six WD 4TB Reds in RAID6 now:
and eight WD 4TB Re SAS drives in RAID6:
https://linustechtips.com/topic/740974-raid-10-speed/#findComment-9395877
