Is 'Primochill Advanced LRT' tubing see-through?
9 minutes ago, lefthanded_legend said:
Oh, I think I confused you with my question. I was referring to cutting the primochill tube down from 1 side, and wrapping it 'over' the stock tube.
I see. But that would be pretty hard as these tubes aren't designed to be taken off, you'd have to rip off the plastic things holding the tubes and then you'd just be covering up a black tube with clear tubing which, if you mask something you lose some visibility. And then you'd have to epoxy or something the tube back on the barb and the barb is soldered onto the radiator. Yes go with 1/2 since 3/8 was a squeeze fit.
If you're doing this anyways means you're losing the coolant that is inside of it. If you just placed the whole thing with clear tube while you're at it, you can replace it with a colored coolant and it would look much cooler.
That's IMO. Also I've never seen anyone do this so it must be a new thing, I've only seen them use AIO to make a custom loop never to cover up the tubing with more tubing.
