Help Upgrading Pre-Built PC
Go to solution Solved by Droidbot,
3 minutes ago, Snowwhisker said:
Alright, thanks, I'll look into it, do you guys happen to know where i can get a new 1050Ti 2-4gb for about $110-$120? I have a pretty tight budget for a gpu, about $125
Do you guys also think i should get a 400w psu just in case, or should i be fine?
Uhhhh.. if you can stretch to $140 you can pick up a decent 1050Ti 4GB, but otherwise you'll be stuck with the 1050 non-ti 2GB which is suited for sub-1080p gaming
I hope i put this in the right spot...
ANYWAYS
I'm a real noobie when it comes to computers (literally just started getting into them about 2 weeks ago) So, I don't know much about them.
I got a Dell HP Pavilion 500y for christmas (prebuilt pc was a mistake) and I wanted to be able to play and record games for youtube, and I realized that my gpu was really REALLY bad, I was hoping to upgrade to a GTX 750ti 2gb and i was wondering if it would work in my system, my specs are below:
Motherboard: N-Alvorix-RS880-uATX
Processor: AMD Phenom II X6 1045T
RAM: 8GB
GPU: AMD Radeon HD 6450
Hard drive: 1.5TB
PSU: Internal 300W (100V-240V)
*MORE INFO* http://support.hp.com/us-en/document/c02679437
I was hoping to be able to play games like Overwatch, Crysis 3, Paladins, Gmod, Subnautica, TF2,  ect. at low - med settings and get 30 - 50 fps while recording, even 20-25 fps is acceptable for me (my current pc can play subnautica but I get 8-10 fps because of my gpu)
from my research ive seen a lot of posts saying that i should be able to play most games at med - high, or even ultra (http://www.notebookcheck.net/NVIDIA-GeForce-GTX-750-Ti-Desktop-Graphics-Card.126721.0.html) with the 750ti 2gb
ive also seen posts saying i dont need to upgrade my psu
my main question is - should i be ok to upgrade to the 750ti without any problems? and should i upgrade my psu just to be safe?
side question - should i be ok to overclock the 750ti also?
Thanks
~Snow
https://linustechtips.com/topic/740382-help-upgrading-pre-built-pc/
ANYWAYS
RAM: 8GB
Hard drive: 1.5TB
Thanks
~Snow
If its the evga one because it needs no additional power and it usually works if u put in to most pcs
1050ti should work as long as you don't oc
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
10 minutes ago, Droidbot said:
750Ti is outdated - 1050Ti is where it's at man.
It should work, but DON'T OC. 300W is pushing it.
then 1050 will work http://pcpartpicker.com/products/video-card/#sort=a8&c=380
You shouldn't need a 400w psu, and if you do get one, no offense but you don't seem very tech savvy and will probably forget to plug in a cord or someshit
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
idk
I think I might be able to get an extra $20 somehow, it might take a bit longer but i think i'll be able to do it.
thanks for the help!
