50 minutes ago, MrTrainCow said:
So I have a graphics card with two dvi ports and a s video port. One of the dvi ports is dead. Will the video card push frames to motherboard dvi port?
The graphics card will only work over it's own ports
you can potentially enable your CPU's iGPU if you need more display outputs
https://linustechtips.com/topic/740221-graphics-card-questions/#findComment-9386638
